What is eta on support for 2017 Buick Encore 1.4 turbo ?
Have you just tried a read from the vehicle with the newest software version of Hptuners? If so and wouldn't read then send the info log to Hptuners support and they can work on seeing if they can get the pcm/os supported if it's not yet.
thnaks for yuo reply
I'd like to see this too, (we also own one), but unfortunately I was told I'd need to remove the ECM to get to the barcode, which I don't feel comfortable doing.
i can read my encore
i add my file
I was able to read mine too, and emailed it to HPTuners support, but they didn't know what ECM I had, and asked me to pull the ECM (by the battery under the hood) to get a clear picture of the barcode.
the technical support (willian ) tall me i can tune my vehicle
Looking at Buick's site, it's still a port-injected 1.4T which means it uses the E78 GM's been using since ~2010. I know for 2017, it's the E78A that has the new read encryption that requires you to be connected to the internet when attempting to read the first time, then you need to try it again after 30min as HPT will send your computer the correct bootloader unlock code to allow you to read it.
This vehicle is supported in the 3.7 beta software.
my encore it is tuned now
Sounds like you mean the sticky: http://www.sonicownersforum.com/foru...ing-1-4-a.html
Thanks I'll take a look at it when I get a chance, but the body shop will have it for about a week (clear coat coming off the bumper) so won't be able to do much with it, except maybe read-all and license it.
I wanted to play with the shift points to make it a bit more responsive for city driving without getting into the turbo. Published zero to 60 times for the Encore are better than my 3500 lb 1.4 liter Volt, yet it drives like a dog for normal driving. Too bad they didn't think to add a sport mode button.
My tuning buddy has years of experience and has been looking at it too, but he's about 8 states away so tuning blind.
Play with yours a bit and I'll do the same and we can compare later.
Thanks again.
Modifying MAP A will help a lot.
Luis, check this out: https://www.hptuners.com/forum/showt...l=1#post492028
