Re: 10.4 & 41.6 Waveforms
GM dosn't use the 2-wire 41.6kbps PWM protocol.
If you wanted to make a scanner for both GM and Ford
this page has some links to Oki Semiconductor's MSM6636 IC for Fords PWM format.
Some of the Packet structure info dosn't look right but it still has a lot of good info on timing requirments.
I'm guessing the 41.6Kbps mode is just the 4x mode GM uses. Which would still be on a single wire.
the links page has a PDF that shows the waveshaping and timing for the 10.4Kbps.
You would probably be able to just factor the 10.4Kbps timing by four for the 41.6Kbps. The timing requirments for J1850 aren't very tight since the auto environment is very noisy, which should make it easier for you.
I'm also just starting on some firmware for a programming interface cable using the PIC16F876. :) It's going to be for the Ford PWM protocol though.
Ok, just wanted some clarification, because i cant find anything on j1850 VPW @ 41.6kbps , just PWM.
