Anyone one know if his books have injector data for deka ev6 80s?
I read they have data but can’t confirm this.
That would be the first dvd.
What’s the title of the dvd and if I want the digital copies from kindle would I not get that info digitally?
To my knowledge the DVD is not on Kindle - just checked and didn't see any DVD available. Summit Racing has it on their site - easy search for Greg Banish. As others have said, the info is not in his books but on Greg's first DVD.
Is it called “ Advanced EFI Tuning By Greg Banish Of Calibrated Success EA”?
Calibrated success is the name of the dvd and book series. you can also get them on his website
http://www.calibratedsuccess.com
https://ls1tech.com/forums/forced-in...l#post20528068
He posted this on ls1tech just the other day. Note that he specifically says the Deka 80s are NOT consistent from one injector to the next.
Greg banish (EFIcalibrator) is still on this forum somewhere, although seldom seen now days. He also did all the injector data for FIC (connection). And yes, Iver heard this about the Deka 80s. Id only trust them if the data came from the same company that I buy them from, Since they should be collecting that data when theyre flow tested.
So his data want be valid for these is what your saying I will check with the company as I have the basic info. injectors flow 80 lbs/hr at 43.5 PSI ( 3 BAR
Static Flow Rate: 80lb/hr = 875 cc/min
Dynamic Flow Rate : 18.6 mg/pulse 2.5ms PW, 20 ms Period
Coil Resistance: 12 Ohms (This high-impedance injector will work with all factory ECM/PCM injector drivers)
Connector: USCAR or EV6
Series: DEKA 4 ( DEKA IV )
O-Ring Type: Viton
Cross References:
Siemens FI114991 or 109-991 ( 109991 )
I will check with the company for the flow rate.. I know at 58psi they should be 92lbs
It's the "other" GM data that can be difficult to find on a lot injectors.
Offset will change with fuel pressure. I gave you a link to the injector data repository. Is that data insufficient?
Here's a datasheet.
I missed this one the thread. Thank you. I have a vacuum reference reg. Wouldn?t my ifr and offset use zero copied through the table? I scaled them down to 62lbs and went through all the Cylinder AIR MASS, LB/HR / Gram/Sec , Torque Tables, etc by taking the .8 row over to .4 and interpoling. Just want to make sure Im understanding you on this offset changing as I have a return coming from the pump to my fpr and another hose coming to the fpr then going to the rails. I thought having a return back to for means vacuum 1-1 ratio?
Another case of no real information given and people having to assume/guess what is being discussed.
