4 Attachment(s)
13 F150 3.5 Dropping Rail
I'm chasing this thing dropping the rail pressure at WOT, new 400 Walboro in the tank, ( stock pump did it to ), Also drilled the bucket with a few holes to replenish the reservoir, new HPFP, New Injectors. This is all with a new engine, turbos, new trans etc. I can go 60-80 tps and make 18 psi of boost and not drop rail, soon as I tip to WOT making the same amount of boost etc I drop rail. Attached is my file and a quick log with a couple WOT pulls and then at the end a 60-70tps pull where it maintains rail. Next step I'm going to install a low pressure fuel pressure guage and see if the low side is the culprit but I'm wondering if i've messed something up in this file.
Attachment 127647
Attachment 127648
Attachment 127649
Attachment 127650
