Greetings
Anyone has the 3bar tune for de kit? Customer does not want to wait 1 week for delivery to mexico of the ecu.
is it possibel to tune one bar and just remove map overvoltage and map/maf correlation?
Thanks for your help
Greetings
you can tune the one bar map, maggie did it in the tune they provided me. Here are my notes when I compared them:
They disabled the flex fuel sensor, not that I can't reenable but thought they said it would work.
Humidity sensor also disabled, not sure why either way as it's a new input for the e98 ecm's.
PE 1.2% increase in higher rpm's, usually like it when tuners never touch this but it is what is.
Piston slap spark adjust also disabled? Interesting?
A 1-2 degree timing increase in the higher airflow rates from 3400-6000, seems normal.
Timing for high IAT's seems to drop from –10, to -5 and scaled accordingly down to –1 70* degrees.
P Engine Torque tables changed heavily from realistic values, to very low negative value in the –5000 range?
Would this be to manipulate the torque based model of the newer generation ecm's?
Changes in airflow coolant sensors as to not fail from readings outside of range, and expected changes to airflow calculations. Normal in boosted applications.
Trans shift times are faster and sooner, not by much but a little. The shift pressure looks to be up a notch and the TCC engagement is bit higher and lower respectively. Also remove tq reduction in upshifts, hmmm…
I am bit hesitant to mess with the trans tune too much, as I have not found a good tune for these that does not hunt for gears and fall on its face between certain shifts.
