e38 ecm code p0606 - clears and comes back
Hey everyone,
I have a L92 from a 2008 escalade in my 96 LX450 (Landcruiser) with a manual trans and a cts-v pedal. I have never touched the throttle tables.
I have been getting the code "P0606 ECM/PCM Processor" every 2-3 start ups, it started happening about 2 weeks ago. It will start and idle with a dead throttle. I can clear the code and drive normally with no issue. The first time it happened I was in the desert 150 miles from home and got back no problem.
I have had this setup for 2+ years and over 12k miles with no issues. I have checked all grounds and wires and everything looks good.
Could it be the ECM is dying?
Is there anything else I should check?
If I replace the ECM and I am unable to do the crank re-learn process because of the manual trans will it run and drive normally?
Thanks!
-Justin
