2001 s10 ls6 4l60 to t56
ive had my ls6 swap done on my s10 for about a year. its running th 0411 pcm with an fbody tune. im going from a 4l60e to a t56. what do I have to change on the tune end.....ive searched here and google,along with other forums......all the answers aren't clear. im fairly new to tuning as well. thank you
You should just need a segment swap to manual. I'm pretty sure you can do it without one if there isn't a proper tune to pull the segment from, but that shouldn't be an issue in your case...
http://www.hptuners.com/forum/showth...wapper-utility
That was written for a previous version of HPTuners, but most of the basics should be the same.
