axle gear tag vs. tune ratio
This is not really what I would call a difficult tuning question, but wondered if anyone can explain it. I have a 2005 Mustang GT, bought it new. On the differential cover there is a small sticker that says 3.55. In the Speedo section of my tune it shows the rear end gear as 3.55. My son just got a 2007 Mustang GT (he liked mine so much he got one just like it, now we have some great father/son car time). Anyway, the differential cover on his 2007 GT has a 3.55 sticker on it as well, but when you look at the Speedo section of the tune file, it shows 3.31? 3.55 & 3.31 were the two available ratios. I will check speedometer accuracy to verify, but was wondering why the "mis-match", and would it effect anything other than speedometer accuracy if I changed his tune to say 3.55, if in fact his speedometer is off calibration. Just seems odd to me...........maybe just a factory mistake?
Axle gear tag vs. tune ratio
Quote:
Originally Posted by
Eric@HPTuners
There are two ways for the PCM to know the axle ratio. It is stored in the VID block, with other information like the VIN number and some other oddball things, and it is also in the calibration. There is a switch we have defined that determines which value it uses.
Thanks for the info guys...........I clicked around in the editor, but can't seem to find the VID block to see what it shows for gear ratio.
I found where the "use VID block" info is ENABLED in the Speedo section.
Just can't figure out how to see the content of the VID block?
Jn2
Yes,
Enabled = Use VID block(stock tire height, no changes to speedometer)
Disabled = Use what ever you wrote in your tune(use this when you change tire size, just be sure your diff ratio correct if you do disable it)
Very excellent info, if I change tire height or gear, I'll just disable the VID and type in what I have straight up in the Speedo section of the tune. But, I still don't know how to see what is in the VID file. Even if it is just to see what the stock info is. How do you read the VID file info?
