The "I'm making my Fiesta 1.0 not so detestable" thread.
Hi all. I'll have owned my 3 cylinder 1.0L ecoboost Fiesta for two years on September 1st. It has 55k+ miles, got it when it had 7 miles. It's been good to me except the lack of power. I was going to buy a Fiesta ST but realized I would be in debt $26k+ for a $19k car so I said nah and decided to buy two ford credits for my Fiesta instead. I'm hoping to also order some stereotypical performance parts from the UK for the car, since the 1.0 is popular there and has been tuned and modded to 205bhp(not whp) by some vendors.
I thought I could apply the other Ecoboost tuning guides to this car but either the tables are missing or the values that should be increased are maxed from the factory. The first thing I noticed was it was running stoich until 5500rpm. Stock MAP here at 4000ft elevation was about 200-205kPa. I bumped up boost a hair to 220kPa. I also tried to run around .86-.87 lambda, but it forced .80 instead and I hit an insufficient fuel flow issue at 5400rpm. I was able to get to .86 lambda and still hit the insufficient fuel message at 58-5900rpm. I'm sure this is fine since I never really go above 5200rpm, but I want to solve the issue so in case I need to go to a higher rpm I can.
Max injection angle is 270*, which I'm debating changing. The other option is increasing HPFP fuel pressure. I do not know if increasing the fuel pressure is feasible. I'm open to suggestions.
My baseline for testing is 20-60mph in second.(This is the safe limit on the road by my house, which I have to run logs on because my laptop has a battery life of 150 seconds.):mad:
Stock 20-60 in second is about 8.2-8.3 seconds
Tuning only enrichment and increasing boost by 15-20kpa is 7.6 seconds
