im looking to buy a hp tuners and i was thinking some one on here might want to sell theres
there is not a classified section on here but you may get someone with this post.
just for some info for you a good portion of the value when you buy an interface is the credits that come with it.
it comes with 8 credits that cost $50 each (49.99) so $400 worth of credits. most supported vehicles take 2 credits to tune , if you add enhancements like speed density tuning for a vehicle it is going to take more credits so $100 in credits is the minimum to tune 1 vehicle.
so if you can buy a used interface for $300 but all its credits are used up $499 for a new standard one would be a better deal
many people that buy the standard interface quickly realize the pro is the better choice since it can put wideband data in your scans real time without having to wire through egr or ac - you cant effectively tune without a wideband unless you are staying cruise or below so you will end up needing a wideband if you dont allready know this...
the pro also logs more frames of your wideband data than the standard can using the egr or ac so your accuracy will be better
^ this may not be exactly how hpt staff would put all this but if you follow what I am saying it should help you make a decision now as if you had a redo using hindsight :cheers:
I started with a standard then got a pro.......
We did the same thing, standard, then pro man...lol
Unfortunately we do not allow "hpt for sale" posts on our forum
How would it work though? I mean you need the numbers that get Emailed to you. Plus you would have no credits as mentioned. Seems kinda like selling a handheld unit with no canned tunes :shrug::D
cant the people selling tell you the number? and if it dint have any creadits. it not worth that much than
