Camaro SS to ZLE Trans Swap, Update OS Help
Hi guys,
I have just swapped an M6 trans from a 2018 ZL1 1LE into my 2017 SS 1LE. The car goes crazy when I try to drive it, and I get the "Clutch Slipping" warning and it immediately reduces the power. I updated the gear ratios in the trans table thinking that was the solution, but that didn't do anything to help. Then I was told I may need the OS from the Zl1 to get it to run properly. Can HPT update the OS on the e92a ECM? I can get the stock file from the donor car if needed.
Any help is appreciated on how to get this thing driving properly.
Thanks,
Jason
