Ford DTC's
This is a list of diagnostic trouble codes. There will be more to come later.
DTC Description
P0102 Mass Air Flow (MAF) Circuit Low Input
P0103 Mass Air Flow (MAF) Circuit High Input
P0106 Barometric (BARO) Pressure Sensor Circuit Performance
P0107 BARO Sensor Low Voltage Detected
P0108 BARO Sensor High Voltage Detected
P0109 BARO Sensor Circuit Intermittent
P0112 Intake Air Temperature (IAT) Circuit Low Input
P0113 Intake Air Temperature (IAT) Circuit High Input
P0117 Engine Coolant Temperature (ECT) Circuit Low Input
P0118 Engine Coolant Temperature (ECT) Circuit High Input
P0121 Throttle Position (TP) Circuit Performance Problem
P0122 Throttle Position (TP) Circuit Low Input
P0123 Throttle Position (TP) Circuit High Input
P0125 Insufficient Coolant Temperature For Closed Loop Fuel Control
P0127 Intake Air Temperature Too High
P0131 HO2S Sensor Circuit Out of Range Low Voltage (HO2S-11)
P0133 HO2S Sensor Circuit Slow Response (HO2S-11)
P0135 HO2S Sensor Circuit Malfunction (HO2S-11)
P0136 HO2S Sensor Circuit Malfunction (HO2S-12)
P0141 HO2S Sensor Circuit Malfunction (HO2S-125)
P0151 HO2S Sensor Circuit Out of Range Low Voltage (HO2S-21)
P0153 HO2S Sensor Circuit Slow Response (HO2S-21)
P0155 HO2S Sensor Circuit Malfunction (HO2S-21)
P0161 HO2S Sensor Circuit Malfunction (HO2S-22)
P0171 System to Lean (Bank 1)
P0172 System to Rich (Bank 1)
P0174 System to Lean (Bank 2)
P0175 System to Rich (Bank 2)
P0176 Flexible Fuel (FF) Sensor Circuit Malfunction
P0180 Engine Fuel Temperature Sensor A Circuit Low Input (EFT)
P0181 Engine Fuel Temperature Sensor A Circuit Range/ Performance (EFT)
P0182 Engine Fuel Temperature Sensor A Circuit Low Input (EFT)
P0183 Engine Fuel Temperature Sensor A Circuit High Input (EFT)
P0186 Engine Fuel Temperature Sensor B Circuit Range/ Performance (EFT)
P0187 Engine Fuel Temperature Sensor B Circuit Low Input (EFT)
P0188 Engine Fuel Temperature Sensor B Circuit High Input (EFT)
P0190 Fuel Rail Pressure Sensor Circuit Malfunction (FRP)
P0191 Fuel Rail Pressure Sensor Circuit Performance (FRP)
P0192 Fuel Rail Pressure Sensor Circuit Low Input (FRP)
P0193 Fuel Rail Pressure Sensor Circuit High Input (FRP)
P0201- P0212 Cylinder #1 through Cylinder #12 Injector Circuits
P0217 Engine Coolant Over-Temperature Condition
P0230 Fuel Pump Primary Circuit Malfunction
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0234 Supercharger Overboost Condition
P0243 Supercharger (Boost) Bypass Solenoid Circuit Malfunction
