I have a afr500v2 I am trying to get setup in the scanner. Both the pre defined hptuners setup and my user defined setup using the math from the manual is making the scanner read 2-3% leaner than the wideband display. This happens in both standard and extreme modes and I am using the pro link on a mpvi2+. Has anyone else had this or know of a fix? Also I am using lambda.
