2 Attachment(s)
6l90 shifts in, out, then into 6th gear 2010 2500hd
I have a 2010 Chevy 2500hd with a recent reman 6l90 transmission after which the TCM was reprogrammed to the latest GM program. Once the learn process has finished it will shift into 6th, then out and back into 6th. I can do a relearn and it will initially shift fine then progressively go back to the shift in, out, in of 6th. The gear command does not change from 6th when it does this. I think it?s in the TCM tune due to it shifting fine when relearn is in progress. Any ideas would be appreciated.
