Read first before posting questions about Cummins deletes!
I?ll put this up here as a read before posting questions about deletes, due to lazy nature I doubt it will actually be read first before questions get posted about deletes, but I digress?
HP Tuners does NOT support emissions deletes!!!
Period!!!
There is NO available parameters in the software to delete emissions. And no, simply attempting to turn off emissions related DTC?s does NOT make a vehicle capable of emissions delete. Your vehicle WILL be in limp mode!!!
Any diesel vehicle that is tuned with HP Tuners that is emissions deleted has been done so through user defined parameters where available or completely outside of what can be seen within the HP Tuners software or completely outside of HP Tuners all together and then read with HP Tuners.
If you have a vehicle that is already tuned by someone else and by another tuning device and is either emissions deleted or not emissions deleted, DO NOT ATTEMPT to read the vehicle with HP Tuners unless your desire is to turn your vehicle into a giant lawn ornament!!! Be forewarned that if you have the idea of reading out someone?s EFILive delete tune or whatever because you want to tune your vehicle yourself and not have to pay for a retune or whatever your reason is, you will have a dead vehicle!!!
If you want to delete tune yourself and own a 2007.5-2009 6.7 Cummins, buy EFILive as that does have the needed parameters already mapped out for the 2007.5-2009. If you own a 2007.5-2021 6.7 Cummins and want to delete tune yourself, buy an MM3 and a Warp Tuning license dongle. Otherwise pay someone who knows what they are doing.
In the case someone attempts to read a delete tune and turns their vehicle into a giant lawn ornament, if it is a 2010+, I can generate a STOCK file, STOCK ONLY! That can be flashed to the truck with HP Tuners with matching VIN, ECM serial number to the vehicle for $50USD so the truck can be started again.
