E39 stand-alone VSS stuck at 158mph
Hi,
I'm trying to resolve a long standing issue with my setup --> VSS stuck at 158mph. I see a lot of mention of this with swaps using the E38 PCM, but I'm not sure I have the right solution. Lots of posts talk about changing the PCM, while others talk about needing a TCM to provide a CAN signal.
Basic info on my setup:
- E39 out of a 2011 Regal (VIN: 2G4G15GVXB9164001)
- No BCM or TCM
- LDK engine
- VSS (GM p/n 55568130) mounted to see reluctor wheel on rear axle (I know this is a transmission speed sensor)
- VSS connector (vehicle side) pinout attached
What I understand about E39 VSS:
- There was a change in wiring in the middle of 2011 model year which moved "VSS High" and "VSS Low" signals in the PCM
- VSS High = +5v --> for my PCM I'm pulling from pin 5 of J2
- VSS Low = ground --> for my PCM I'm pulling from pin 21 of J2
- Voltage measured at sensor across VSS high and VSS low is confirmed to be +5v
- VSS signal is pin 8 of J2
Questions:
- In the 2011 and later Regal where does the wire from Pin 8 of J2 go (VSS sensor or TCM/BCM)?
- Is the PCM expecting a CAN signal to Pin 8?
- If the PCM is expecting a VSS sensor input, is there a different sensor I should use?
Thanks,
Daniel
