Hello, what is the correct place to correct fueling on 2019 f150 trucks?, speed density calculator?? and what is the correct way to use it? thanks
Yes the SD calculator is your main tool for correcting fueling. A lot of good write ups on how to use it, but fairly straight forward. You do need to be logging a few more things to get a full picture of where work needs to be done. You are pretty lean until closed loop catches up and corrects through the first gear you get into boost. I would play it easy until you get some fuel in it down low.
quick hack/load/rpm fuel multiplier
