What area / tab do I adjust timing . Theres 10 of them . How does the cm2100 ecm decide what 1 of the 10 it wants to use? Are they staggered by load a certain percent?
Same as every other ecm for the Cummins, the table that gets selected is based on air density and which emission system is active
No, not a good move.
First step is to data log and learn what operating modes are used and when and how things operate. Then make small adjustments in operating areas once you figure out where it?s operating and what it?s doing. Or you can just put a blindfold on spin around in circles and hope when you throw the dart you?ll hit the board.
