2 Attachment(s)
1999 GM 2.2 Custom Tuning Help
So my project is a 1950 Crosley with a 99 s10 2.2 and 5spd trans.
I know the 2.2 is tune able with hp tuners but I've never messed a lot with ecu's and tuning. A local guy i know has HPTuners and mentioned something about re flashing it? I know i need the security removed/egr/fuel pressure sensor/rear 02/etc deleted out as there no longer being used. Is that something that can be done? When re flashed does that mess with timing? He also mentioned he can set a signal for fan relay to come on/off at set temp. With some research comparing a 99 cavalier and this s10 ecu i found pin#54 to be the signal for fan relay. I installed a pin and wire and ran to relay. I also hooked up a mil light and the obd2 port tonight.
Attachment 129107
Attachment 129108
