hello to all of you I'm robin is it possible to put a flexfuel sensor with a med17.1 and have the adjustment channel with hptuners thank you
:pray:
:pray:
not with out some custom coding with tunerpro
Thank you for your answer GCtech
do you have an idea of the coding done?
thx
Sorry to burst your bubble. But "TunerPro" on its own will not cut it. You need to modify the ECU logic by disassembling the program code. Some people do it with Ghidra or IDA. Requires lots of experience.
thank you for your message tommerrr
Did you find examples of coding?
You are likely better off getting an ethanol gauge and building tunes based on ethanol percentage and flashing the relevant tune for the ethanol percentage
