7.3 godzilla vct mapped points
So collecting data driving around in the godzilla I found the only mapped points for vct used are 0-5. And it's only used optimal stability and fuel economy. Mapped points 6-26 and OP are not enabled. I only have been studying the coyote because there is nothing on the godzilla available. So is there any use playing with the vct on a overhead valve vct engine? Could some one enable more mapped points some how for WOT and gain any power out of this?
Say turn on mapped point OP then enable pedal position to say 75% for OP. Then changed the axis table to 3800 RPM-6000 RPM. Would this then allow me to change OP valve angles and find a little bit of power out of it?
Hope that made sense.
