New to data logging. Can someone guide me hooking up my Autometer AFR #4397 in the scanner suite?
Just want to make sure I do it right.
Hooking up ProLink to the gauge is not the issue. It is just setting up in the scanner
THanks
Bryan
THanks
Bryan
im having the same problem. Did you ever figure it out? i cant find anything on the 0-4V instead of 0-5V
I'm in the middle of doing that exact thing right now, with the same gauge. Same questions!
Anyone get this figured out? I find it hard to believe there’s so many different transform equations & such used for serial logging wideband sensors with inputs of either 0-5v or 0-4v. Personally I’ve been trying to get anything to show up with my auto meter phantom but would prefer Lambda. I don’t even know if anything I tried works because as soon as I start logging the channel disappears
