throttle body start to oscillate when map goes 1-2 psi of boost at part throttle. also it takes some time until throttle body goes full open.
any help? thanks
any help? thanks
its not just slow to wot...
looks like it should be open more than it is for the voltage it is seeing
most of the airflow tables look stock
i have a bunch of ideas but no experience : )
magnuson comes with its own tb yeah?
yeah i dunno. you put a super charger on a engine that has 4 cams, variable valve timing, and variable LIFT as well
you have the stock file?
Airflow tables, throttle tables and cam timing (and a heap of other small things) need work with a blown pentastar.
Use this tune as a guide as to what needs changes and what doesn't.
there ya go.
that will not just lock the ex cams, but it will bring em forward almost 50 degrees before it does , )
