Maf Tuning Spanish Oak
2011 Crown Vic based platform. 4.6 DOHC with 76mm turbo. I'm slowly working on the tune. I've been trying to figure out how to set up a histogram for maf tuning, but all the info confusing or doesn't seem to apply. What PIDS can I log and use to create a histogram that doesn't require a WB?
I know its not helpful, but I wouldnt do that without WB.
You can only set up closed loop with maf vs fueling.
Use the anticipation to get faster response for closed loop.
The spanish oak is real basic.
2 Attachment(s)
Is this an engine swap? Crown vics are a SOHC 4.6l from ford. This thread may help you out: https://forum.hptuners.com/showthrea...mp-WOT-Surging
Yes this is a engine swap. DOHC from a 93 Mark 8.
Wideband is going to be required for proper tuning. Lots of add on options and use one of the mvpi external ports.
