Is there a way to turn off the adaptive learning for the 10R80 transmission? I know we can reset it using the VCM scanner, but I?d like to turn it off entirely. Ford IDS has the option.
Yes, this can be tuned out
Shift pressures/General/Steady State General
Welcome to HPT forums, where your questions will be answered with yes/no with no real substance.
Under shift pressures/steady state general, zero out the maps. It's basically telling adaptive to not update if torque is greater than that number, so of course it will disable if you zero them out.
For anyone that's turned these off and put some miles on since, was there any adverse effects or unusual behavior that made you turn them back on?
