2 Attachment(s)
07 gt500 idle hang after injector upgrade
I installed FIC 775cc injectors and entered the data they provided. Car starts and runs but the idle hangs if revved up sitting stationary and if you drive it the hang is worse. I tried changing idle airflow, all dashpot settings, integral and derivative, spark cold and emissions adders. At one point I had all the dashpot settings zeroed and all the idle airflow zeroed. Still did not change much but will go into limp mode. The tune I included is on the car but I need to put the integral and derivative back to zero still. The log is just idle and moving it around in the driveway to see if it was still doing it. Another thing that this car has always done is at the beginning of the log you will see the STFT bank 1 go to 25% for a couple seconds then reads normal. It does that every startup for as long as I have owned it. Always thought it was odd if anyone has any input on that. Any idea's appreciated.
