Hey everyone, just picked up a mpvi3 for this thing. I want to adjust the torque management and shift rpm/speed for starters. Which set of parameters are to be adjusted for this? Thanks in advance
Open VCM Editor. Click OS. Apply RPM patch code modification.
Nothing seems to change the shift points for this thing. I set rpm limiter higher and even in manual, 6200 or so max
Changing WOT should have an effect.
The others won't matter because the transmission is in Torque Based shifting schedule instead of by gear.
Which section would that be in? Because I've try numerous changes to this
This is from a 2013 F-150 5.0 file:
Attachment 133555
You've tried changing it?
Ohhhh. Maybe you have to go to Airflow>Electronic Throttle> Pedal Pos WOT Start and End. Sorry didn't think of that. It's one of the first changes I make.
Pedal movement is 0-512 counts.
Start = 436
End = 496
Wot shifts set to 6500, and pedal movement set, still no good. Maybe even worse. Shifts 56-5800
Figured it out, now hitting 7k on the shifts. Now to get them a little quicker and firmer. Also noticed the throttle not opening as fast as the pedal. And how can I get some of the torque management off?
Figured it out,
Care to share what you figured out?
Many of us have never seen a gen 1 truck
What was the fix?
Get me a log with these settings. Let's see if a limiter is in effect.
Turned all rpm limiters to 7500. I believe the 1-2, 2-3....shift mph is what changes it. My laptop is at work so I'll load the log tomorrow
this work?
Yep no limiters active.
