2 Attachment(s)
P01 ecm not reading voltage from aem afr on egr pins
I am working with a P01 411 ecm and I am wanting to datalog an AEM 30-0300 WB. This engine (5.3 LM7), wiring harness and ecm all came from the same donor truck. 2001 sierra 1500. The egr was deleted when installed into my 80 Grand Prix. I am using pin 23 and 55 on the blue connector and have voltage between them when running. White wire from afr gage to pin 55. Brown wire to pin 23. I have also tried brown wire directly to chassis ground. I have gone into the engine diagnostics/DTC and turned on everything to do with EGR. Have added EGR sensor (voltage) to the channels. And that is where I show 0.00 volts. I have removed and added it a couple of times double checking settings. I have added editor and scanner files
