2 Attachment(s)
2018 Procharged LT1 Corvette 6,000 RPM issues
A little back story, last summer the car had a procharger installed. Baseline numbers where normal, the Procharger is installed and it goes back on the dyno. Now I that point (I went back and looked again), I had tuned 73 stock LT1 vehicles with and without boost and many more built LT1 based built vehicles, with many into the 4 digit club. I setup my calibration for a stock LT1 with a Procharger and first pull was about normal, everything looks good so I add some timing and go for pull number 2. This time the car looses about 50 rwhp. I see right around 5500-6K it pulled timing for knock, I was low at only 8 or 9 to began with, so I removed the two I just added and did pull number 3, this time I'm down 70 rwhp. I do a compression test and two cylinders are low on compression but the car runs good, idles, no smoke. So it comes apart and broken ring lands on two cylinders. I'm amazed because after all these LT1 engines I have never seen a stock piston failure and this was with low timing just starting on tuning. So the pistons are replaced, see nothing wrong, but also replace those two injectors and go back on the dyno. Low power and its not really responding after half a day, we check compression again and one of the same cylinders is low on compression. Not as bad as before and only one cylinder. So it comes back apart and broken ring land. This time we pull the engine, go drop in pistons and rods, replace all the injectors with LT4 and an LT4 HPFP. Put it all back together and it idles ruff on start up, but smooths out when warm. Installed Meth as an extra safety and went back on the dyno. Almost every pull on the dyno was low on power and at 5500-6K the car would loose power and pull timing. Some runs it would pull almost nothing and I would get a decent pull to 6500, still loosing power by 6K. Other runs it would pull 2-12 degrees possibly more. My best runs on the dyno where with knock disabled, meth on and timing at 17 degrees. Power was still low in the low 500 range when I would normally see high 500 to low 600 range on my dyno. The car came off the dyno and timing was set to 13 degrees on the top end. Better to be safe, not a power house but it would do. A year goes by and the car comes back with a few issues. First the car will idle so ruff after start up for the first few minutes until warm it will set a random misfire. This started after the lT4 parts went in, so possibly I have something set wrong. Once warm and the car was being driven around it had this surge feeling, looking into it the car was pulling max fuel. If I turned off fuel correction all the surging was gone and it ran perfect. Looking over the tune, I had swapped over the LT4 SOI and EOI and they are completely different from the LT1. Changed them back and fuel correction went back to normal and the surging was gone. I was thinking this would also fix the cold start misfires but it didn't. The owner of the car doesn't normally drive it his wife does so its normally not taken to redline. well he started hammering on the car and at 5500-6K the car hits a wall and falls on its face. This happens 90% of the time, however 10% it will make a clean pull. During a drive yesterday I got on it twice. At 5500 you can feel the car start breaking up and by 6K it just wont pull anymore. The pcm pulls lots of timing at this point in the last three days I have seen anywhere from 2-16 degrees pulled. I don't have lots of timing to start with Have confirmed the meth is spraying. Its the same problem as last year, with meth, without meth, with old injectors, with new injectors. Anyone have any ideas.
thank You
Bad383TA
