Originally Posted by
PurpleRam
The 5/7 thing relates to dry air flow before injector, let’s say #5 gets 100cfm of air & .0660 gms of fuel, # 7 might get 98cfm &.0660 gms of fuel, logic dictates 7is richer than 5 at this point, so 7 stumble, wet manifold would be different. Now in high map situation its more likely, now the boosted crowd do not have this problem, the “boost device is force feeding the cylinders, while na (fundamentally) has to solely rely on vacuum created by piston draw to fill the cylinder, low map situation there’s more “air” to draw against than high map. Low map(10-40kPa) high map (70-105kPa)
