3 Attachment(s)
CAMMED/SUPERCHARGED 1LE CAMARO IDLE ISSUE. Negative timing ruining all the fun.
Hey guys, I have another 1le tuning issue. It's procharged, did the bottom end and cammed it. It runs okay but the timing is still negative and it sounds like butt. I have a scan from the same tune in MAF and VE mode. Runs about the same. What should I try next. Adding a bunch to the maf or play with the vvt a bit more. The torque numbers at idle are pretty low already. These 1le Camaros are really touchy with the timing. In stock form I believe they sit at 0-1 degree
Attachment 137596Attachment 137597Attachment 137598
