Do you know what size resistor I need ?
Quote:
Originally Posted by
nikjt76
Is there a way to turn off the dual stage oil pump on a Pentastar 3.6? Or even turn off CEL warnings around the two stages of oil pump, I'm forever chasing a P06DD code the same as many many other people with Pentastar's.
Everything has been changed to try and fix it, oil pump, oil cooler, timing chains, many oil filters and oil changes, oil pressure sensor. The engine is running fine, other than putting it into limp home mode due to the P06DD code.
The engine also seems to run better when you disconnect the oil pump solenoid and attach a resistor to simulate it and prevent a P06DE code when detached.
I just want to turn off the dual stage oil pump, is this possible in the HPTuner software?
