2018 R/T 5.7 with supercharger tuning issues
We have a 2018 Dodge charger R/T here with a 3.0 whipple. Customer went with whipple tuning. With that said, we currently have 17 codes ranging from IAT sensors to Camshaft sensors to MAP sensors to coolant, pcm comm issues, etc. We've done everything in accordance with the instructions in regards to uploading the tune. Upload tune, turn off, open and close door and wait 30-60 seconds to help prevent comm errors.
Current issue: the car wont start, only way for it to start and run rough is unplugging the pcv on the passenger side.
Whipple is stating its mechanical and the MAP isnt plugged in, I can only assume the sensor is bad so we'll see if whipple sends a new one out.
PCM was sent to HPT to get unlocked, security gateway is installed. I pulled the file from my MPVI3 and whipple is stating that is the correct tune installed yet here we are. There's only one plug that comes with the kit. MAP and IAT harness. IAT plug T's off the MAP sensor. Not many plugs to screw up. With that said, anyone else have these issues?
