1 Attachment(s)
trying to tune my 2 step but my IAT spark advance table only goes down to +14 degrees
I wired a relay into my IAT sensor intending on going to my IAT spark advance table and commanding it to pull timing at that temperature that it reads when i hit the button. The IAT reads -19 when the power is cut to the sensor. When I went into my iat spark advance table to edit the tune, i noticed that it only goes down to +14 degrees fehrenheit. Also, rather than reading in cylinder airmass versus temperature, it reads MAP vs temperature. The problem I am facing there is that the MAP only goes to 100kpa in the iat spark advance table even though I am running a 3 bar OS with a 3 bar map sensor. How can I fix this? I thought I had a good understanding of how to navigate VCM editor but apparently I do not. I will attach the tune below.Attachment 138612
