1 Attachment(s)
flare shift cant figure out how to stop
log attached with part and full throttle shifts
Attachment 139107
2015 6l80. log doesnt show it, shifts look fine on log to me. Anyway I,ve read the forums and watched videos and i can not fix this issue. my 1-2,3-4,4-5 shifts are perfect, feel fine and shifts just right. the dreaded 2-3 shows up fine on the log, shift time shows its good, however it seems to hang between 2&3 before 3rd engages fully. i have added oncoming preset pressure and it doesnt help, just makes the slam into 3rd harder when it finally hits it, so i went back to as found values for 3rd. i have max adapt volume at 200, preset oncoming at as found values( not sure if stock or not) shift time set to match 3-4 which shifts beautifully.
is this in the offgoing pressure preset or somewhere else?
shift points tuned with bluecat tool, everything seems happy except the 2-3 for some reason. i even tried copying everything from the 3-4(then the 1-2) into the 2-3 to see what that would do and it didnt help at all. didnt change anything. i reset adapts each time i made a change.
