7 Attachment(s)
Rich coasting condition on procharged silverado
Problem:
During a baseline dyno run the tech mentioned that the truck was coasting a bit rich and verified that my wideband was accurate (i had ignored it because the guy that tuned it said my wideband was wrong) . Started checking the tune and trying to resolve it myself but seems like no amount of changes will bring the afr in check during coasting.
Mods/setup:
This is a 01 silverado 2500 6.0L. The engine internals are all stock, i have a d1sc procharger, 80# seimens deka injectors, walbro 225 fuel pump, custom 3" exhaust with an H pipe and (unknown to me at the time) a 28" z bend 3" inlet to 2.5" outlet muffler for each pipe. The fuel rail does have the factory return line. The shop that tuned it did the 2 bar map upgrade, and set it up to run without the maf. I put a smaller pulley on the sc(4" to 3.8 IIRC), added a bigger intercooler, and recirculated the bypass valve since it was tuned.
Failed attempts:
so far ive tried tuning the ve table, the 15-25 kpa range the values are getting low enough that i don't feel comfortable with them(if low values like that are ok lmk), ive also been trying to tune the base idle airflow(cold starts are improving). The injector data that was in it from the shop was off from some resources i found and the data i found seems to improve its response to tuning. Today i tried changing short pulse limiter, short pulse adder, and minimum pulse but the rich condition persists making me think that this is not related to injector data.
Help:
1.Does the ve table that the shop made for me make sense, mainly it looks like it has been scaled to give a safe spot for a runaway turbo/wastegate scenario and im wondering if i should revisit that.
2.I know there is something im missing with the whole 12-10 afr while coasting any input is greatly appreciated
3.Why are the stft's able to lean it out while coasting but i can't seem to get it in check in olsd
4.Anything else look funky let me know
config
Attachment 139636
Graphs
Attachment 139643
Log and file olsd (trying to get some response)
Attachment 139637
Attachment 139638
Log and file stft's enabled
Attachment 139639
Attachment 139640
Original tune from shop (they were trying to make revisions for -10F cold starts)
Attachment 139641
Thank you.
