4 Attachment(s)
C5 M6 new engine mods, idle tuning issue
Hi, I added the following to my engine, need help with tuning idle settings.
Engine starts and idles rough for a few mins then stalls. (1st hpt and log files)
DTC error: P103 MAF
Would appreciate any help, thanks.
I updated the idle settings for Base Setup.
Runs much smoother for longer then stalls (2nd hpt and log files)
No DTC errors
Fuel pressure is 50 lbs at start up and increase during idle to 60-65.
3/8 tank of fresh 93 octane gas
Clears all DTC?s and also cleared error history in dash.
MODS
1999 LS1 engine, stock bottom end, stock pistons
A&A V3si blower, 3.6 pulley, innovators west 10% overdrive damper
BTR stage 1 Blower Cam (Dur @ .050 217 23x, Lift .619 .607)
799 ported heads stock size valves, stock deck size, not milled.
BTR double springs, stock rocker arms, LS7 lifters, 7.4? pushrods
FAST 92 intake, 3 bar MAP sensor (AC Delco 125 92525)
LS2 90mm throttle body
Racetronix fuel pump FOA-005A, rest is stock
Deka 80# injectors
Elite engineering catch can, 1 exit port to engine intake, 1 exit port to blower intake (when in boost)
1 3/4 stainless steel headers with high flow cats and Corsa Indy exhaust
