05 6.0 with kc 10 blade and 4? exhaust. what?s settings can i change to get the most whistle at idle and settings while cruising?
What strategy are you on?
If your on a non inferred strategy you won?t be able to do it as well.
In you EBP tables down at idle around 0-22mg and from 0-700 or 800rpms. Jack up your pressure to 200kpa
That should get your vanes to close at idle.
Vxcf9ca
Not mistaken your on a non inferred Strat.
Try to do what I described up above and see how that works. Either way that is the way I make the whistle in my tunes whether it is inferred or non inferred
