As the title states, is that a good assumption? :doh:
Component protection sounds more like Cat Over Temp to me (not Power Enrichment). Just my 2 cents. :)
way different specially for ME9.7
Is there an equivalent to command AFR/Lambda for WOT?
I have a different ecu, but for me component protection is what I use. I have a base, or target map, and a 2nd fuel map. It apparently switches to 2nd based on exhaust temps, so I make target more or less oem, and 2nd richer. I also have a power enrichment map but doesnt work right so I dont use it. If thats of any help.
In a nutshell, yes it is the same concept.
EGTs are what seem to control commanded fueling on most European cars that I have tuned. Be careful for the difference in actual vs modelled EGTs though.
