Help Please 2015 Ram 1500 5.7 MDS disable Failed to write
Hello,
I just deleted a 5.7 hemi removing the cam and lifters. I downloaded the PCM's OEM file and saved it. then change the MDS to disable and attempt to upload the "calibration". I keep getting a "failed" message with " invalid checksum ". When I double-checked the car with an Autel scanner it stated the PCM is not programmed. I sent in my files to HP, they got back to me fairly quickly. They said both files look fine. I was dealing with PETE at HP. It was late Friday and we ran out of time. I have performed this many times in the past but not 2015+ I have to give the customer an update Monday so I am reaching out here to see if anyone else has experienced this. We do you a Flash compatible Charger when flashing any vehicles. so voltage is not a problem. if anyone from hp tuner is looking the support ticket # is 408007.
Thanks for anyone and everyone's time in advance.
oh no, people have looked and didnt comment.
Quote:
Hello,
I assume this is a big problem since no one has commented.
