HELP Need 2010 6.7L Manual Trans Stock File
Hi everyone, I'm having trouble tuning a 2010 Dodge 2500 6.7L with a manual transmission. I can't seem to read the file from the ECM; first off I tried to read the ECM with a slightly older version of the VCM Editor, and it would read to about 50% then say "read failed". So I tried with the latest both Beta and Stable versions, and they both say the same thing - "Incorrect Communications Protocol Detected" - or something to that effect; then no connection. The truck had some emission related codes popping up in the older VCM scanner, but after updating, I get the same message about comm protocol and no connection.
So after all this I got out my Launch scanner, and I had to make it believe I was working on a 2013 or newer truck to get connected; then the only thing it showed was the U1601 code (no vehicle info, no data, no more emission codes, nothing).
ANY HELP WOULD BE APPRECIATED!
Also does anyone have a stock tune that they wouldn't mind sharing? I'd try to flash the ECM if I had a file.
Thank in advance!
