Using a WB SD tune to calculate a new MAF table
Theory here
When the MAf is diconnected the PCM uses the ve table to figure out dynamic airflow, could you log RAW MAF frequency and then derive a table from the dynamic cylinder air pid (in g/sec). This way the maf models the engine flow and characteristics. This also takes into account any changes to the maf and the intake tract.....
What do you think???
Edit/Delete Message
Re: Using a WB SD tune to calculate a new MAF tabl
Should work, first your going to have to use one of the EIO inputs to bring in the maf Frequency so you can log both the SD calculated air flow and the Maf HZ at the same time., then you will painstakingly have to rebuild the maf table cell by cell.
I think it easier to just tune VE using speed density, then reconnect maf and then rescale maf table as need to get trims back in line.
Aaaah. That makes sense too.
Actually you can have the maf hooked up and force the PCM to run in SD all you to do is set the P0101 table under Engine diagnostics to 0. This should take of the MAF and you will still be able to log the frequency through the PCM
I am anxious to hear somebody test this out. I am too darn busy to blow the dust off of my MAF and reinstall it...
I have someone that will try this out tomorrow for me. I will post back with the resultls
Dirk - What were the results of this test?
Yes... what were the results... ???
Never got around to it. It started snowing where he was from and I couldnt find anyone around my area to help me with the tests
