4 Attachment(s)
Narrowband? Wideband? Exhaust leak? Running Lean.
2003 C5 6 Speed. Stock car, Cat delete, AEM 30-0300 wideband.
I tuned the MAF and VE tables separately with fuel trims off.
When I turn the FT back on the car pulls ~8-10% fuel out right away. Now since both narrowbands agree I'd want to think my wideband is wrong or I have an exhaust leak after the O2. The only thing making me thing differently is if I command the desired AFR with my VCM scanner and Closed Loop disabled, My wideband almost perfectly follows my commanded AFR. It's as if both my narrowbands are skewed and want to cycle around 16.6:1 AFR.
I had an idea that since the stock stoic is set to 14.63 and modern fuels have more ethanol than in 2003 that changing the stoic to 14.08 would fix the issue, but when I tried it made no difference.
I'll post my stock file, current file, drive log, and idle log of me controlling the commanded AFR.
Attachment 143483
Attachment 143484
Attachment 143485
Attachment 143486
