1 Attachment(s)
help with setting up ve table. on boosted scat pack someone take a look?
so im having a issue with tuning, i had someone setup my injectors and 3 bar map, the car runs ok but my ve table is only set to 100 like stock i have set it up but i dont think this is correct , i feel like i should setup the ve table to go past 100 as i have about 10lbs of boost do i just change the numbers on it ? please help with what i should doAttachment 143668 i see other tunes i have for supercharged scats and the ve table is set to 160 im not sure if i should just edit the row numbers and it will do it, or if i have to enable something in the tune
