4 Attachment(s)
Spark Cut Between 30-45% Throttle
I have a 2007.5 Sierra 5.3 that I swapped a stock 6.2 into. I copied as much data as I could from a stock 2007 Yukon 6.2 file to the stock 5.3 file. It starts and idles fine, drives fine until about 30% throttle when the timing goes nutty and starts to buck. If I keep my foot on it it accelerates normally once it gets through that area. It seems like a low load area to be getting into torque management..? The MAF is stock 5.3 and left it alone in the tune. The MAP is a Bosch which I set up based on a 2010 6.0 2500 file.
Anyone have any ideas as to what could be happening? Attached the stock 5.3 and 6.2 files, the combined tune that is in the truck and a data log of the trouble spot.
Attachment 144907
Attachment 144908
Attachment 144909
Attachment 144910
