2 Attachment(s)
HP90 swap issue on 2020 Charger scat pack
We swapped a 2018 HP90 into a 2020 Charger Scat Pack and on the dyno with zero mph registering on the dash, the vehicle performed without an issue. Realizing we did not swap the tone rings onto the new rear axles, we fixed that after the dyno runs. While on the dyno, the trans output signal had mph so it would shift just fine as well. Driving the vehicle on the road, light throttle is okay along with wot, but if you step on it some the vehicle cuts spark and then fueling to limit it. It's showing over temp as the reason, but trans temp is only 135-158deg on the dash and log data. I also have the tcc temp raised in the tune. What is the over temp for if not the trans temp? I don't see a tcc temp pid to log either to verify a temp it might be seeing. Anyone dealt with this issue before? (built engine, procharger, hp90, circle d stall)
