2 Attachment(s)
Speed Density Turbo Tune Timing going (-) at 2-3k RPM
Hello, I'm finally getting enough progress with my current build and tune to feel comfortable with posting. I'm running into a wall and believe its torque management pulling timing once i begin to build boost. I know my VVE Tables need work but the truck is just a dog.
Refreshed 6.0l LY6 in a 07 GMC Envoy Denali (LS Typhoon build) E67 pcm, LS9 Cam, 823 Heads, 7875 Turbo, Lingefelter in-tank Fuel Pump. Still the stock A4 trans.
Flow match Fuel Injector Connector Deka 80's with data sheet input, NGK BPR7E plugs gapped to 0.022. All TCS Patches have been applied by Write Entire.
I've scaled fueling for injectors by 0.5, Doubled Stoich, and Halved IVT AFR term. Truck ran much better after mult. the Torque Coeff -EQ Ratio table by 0.5. I still feel there is something I've left out or overlooked. Been searching for a few days but no immediate solutions apparent. Truck is much more responsive when manually selecting gears.
Any Ideas? All modifications to stock file has been documented in Tune Details. I've tried to group modifications by Tab.
Thanks!
Attachment 147711
Attachment 147712
