3 Attachment(s)
Poping sound at idle, help..
got a 96 Camaro 5 speed, FJ250 injectors from the 3800 SC that is rated at 36lb/43psi, also running a 97 Camaro pcm.
did rods and bearing, and installed new gaped piston rings for boost because I'm running a single turbo, higher rated valve spring and then some..
I've been having this issue where the car would run and idle perfect when it's first started in the morning and running rich 12ish.. the closer I get to 14.0-14.7 the car starts making a popping sound out the exhaust, I've tried messing with the injector data, i tried messing with the spark, and noticed the car would pop way less at like 14 degree of timing, but no matter how much I try changing the main spark advanced it doesn't stick and just goes back to 25 degree.
it does it in open loop, and closed loop.. so far I've changed pretty much all the sensors, spark wire, coil pack, spark plugs.. I don't think it's a internal problem because i can make it stupid rich and it idles fine with no popping.
if their is a 3800 god out there I would love to get this problem solve
Attachment 148158
Attachment 148157
Attachment 148156
