2 Attachment(s)
slow times at track, overtimed?
E85 / 8psi / L76 / tr6060 / 20 degrees timing / .81 lambda target.
Hey guys I finally got around to going to the track in my G8, I only participated in the roll racing section as I dont have a tire yet. Anyway the best trap speed I could achieve was 124mph from a 40 roll.. That seems pretty low to me considering this car made 550whp on 93, and is now on e85. Looking at other cars with similar setups, they seem to run 130+ in the 1/4 mile.
Whats odd to me is im getting slight KR towards the top of 4th gear, with 20 degrees, which 20 to me sounds pretty low for ethanol, but what do I know.
with the gearing it has currently, im shifting into 4th right at the 1/8th mile, and running it out to the end. This was also on a 90 degree day, probably didnt help anything.
In the file, the stoich is all jacked up because I found that my flex fuel sensor ethanol content drops at WOT, so i just made it all the same number to avoid issues there. Im pretty sure I need to move the sensor to the feed rather than return.
Attachment 148104Attachment 148105
Thing feels great until you hit 4th, it seems to struggle to pull that 1:1
