LBZ 63mm Fleece Cheetah Issues
Swapped a brand new 63mm cheetah turboh from fleece into my truck and have been getting p0299 underboost codes since, it is much more lag and black smoke then the stock turbo unit. Bumped VPS MAX and low alt table for now (I'm at 1k feet above sea level). Still just barely getting it to hit desired boost levels and very slow to spool from idle. Table is up to 90 on the bottom end for desired VP so will not have much room when using the truck to haul trailers in the mountains.
Whats been done to the truck:
headgaskets
heads rebuilt
ARP Head studs
EGR not leaking
PPE high flow up pipes
lmm driverside manifold
new donaldson filter
swapped MAF with a known good one
swapped MAP with a known good one
Swapped VPS with known good one
IAT and ECT sensors reading accurate
barometric pressure sensor in ECU reading accurate
pressurized post compressor to 30 psi and no boost leaks found
pressurized turbine drive side, slight bubbling found on passenger side manifold to up pipe connection (cannot hear this while driving the truck)
measured pre CAC pressure VS post and see about 1 psi delta at low load and 4 psi delta at high load (pressure loss good with the change in air temp accross the CAC)
Anyone else running a turbo similiar to this size and running into the same issue? or is this possibly a bad turbo from fleece (possible wrong clocking of the VPS wheel to the actual vanes)?
I have been in contact with fleece and they basicly have been zero help saying there turbo does not set underboost codes, and suggested that all trucks are different and do not know if it needs a tune or will run ok on the stock cal. GM sells all the LBZs with the same calibration so that kinda goes against what fleece is saying when they say it may or may not need a tune to work good.
Any help or suggestions appreciated. Thanks
